Fpv Problem
I bought a 900 mgh fpv kit from hobby king and it won't work. It does't seem to even try to show video.
The camera, and transmitter heat up when I plug the battery in. Any ideas. Thanks.:confused:
Zatoichi
#2
HeliGuy101 when I got mine from H.K.( CN20012RX4T)I can confirm that the wires are reversed as so many others have already stated. You don't need to re-solder anything, just use a pin to push down and out on the connector in the plug and reverse the red and white wires. I hope this helps out
robschonk
#4
Mine needed the wires switched, the tx dip switches with 1 on and 2-4 off, and the rx on channel 3.
Also works on 2s battery without the tx overheating.
