Have you fixed it? Mine came with the same problem. On the white connector, you'll see a tiny plastic flap/tab just behind where you can see the metal connector inside. Take a pin some small sharp object, lift the plastic tab and pull the wire out. Then just push it back in. Hope I've been able to explain it.
