FPV System - 900Mhz Hobbyking~ Wiring Fault
soapovis
Hello,
I recently purchased the hobbyking 900Mhz FPV Kit.
I noticed the wiring that goes to the camera is backward,
Mine is :
VIDEO NEGATIVE POSITIVE
its supposed to be
POSITIVE NEGATIVE VIDEO
how do I re-wire the wires to be the right way?
thanks in advance, ;)
-axel.
Have you fixed it? Mine came with the same problem. On the white connector, you'll see a tiny plastic flap/tab just behind where you can see the metal connector inside. Take a pin some small sharp object, lift the plastic tab and pull the wire out. Then just push it back in. Hope I've been able to explain it.
