FrSky DJT module wont fit in 9x!
Carbon
Elemental Madness
fit issue. The corner where the pins are wont seat, like it is just blocked by something.
lobstermash
Propaganda machine
Sounds like it's blocked by either the pins or the bit of plastic at the base of the pins... I've heard of some people having fit issues, but it's been fixable by slightly enlarging the square bit around where the pins go into the module. Can you post a pic of you tx without the module, and the back of the module?
Carbon
Elemental Madness
sure, give me a sec
Carbon
Elemental Madness
there you go^
I think it is the bit of plastic around the pins. Stupid design.... :mad:
lobstermash
Propaganda machine
The idea of the plastic is to isolate the connections and make a snug fit with the module... Are you able to wiggle the module side to side as you push it in?
It does look like your plastic bits stick out a little further than mine, by maybe 1mm or so, but it's hard to tell from just the photo.
