I don't know if this is the right place to ask this question, as I don't know if this is a radio question or an esc question or both.
I just bought a flitetest flight pack b and c and I can't get the escs to arm. I have tried connecting the battery when the transmitter is at throttle off and also with it at full to try to calibrate it. Both just give a 231 musical tone regardless of the throttle setting and then there is nothing. I have a 72 MHz Futaba transmitter with a 2.4 ghz frsky module installed and set so both bands can be used. When using the frsky receiver i can't get the esc to arm. But if I switch over to a 72 MHz receiver it fires right up.
Is there a known issue with compatibility between Frsky receivers and BlHeli escs?
I tried extending the end points on the throttle to see if maybe the esc wasn't picking up full throttle and no throttle, but then when the other receiver worked without any adjustment that kind of threw that out.
My only clue is that in the blheli manual under "programming via program card" it says that when the esc is connected to a program card and then connected to power there will be a 2 second pause followed by the 231 tune. Which is what it's doing for me when plugged into the receiver. It seems like the esc thinks that the receiver is a program card. I'm at a loss for what to try next.
