FT-22 Raptor - BUILD
Flynn
Here's my 78% build (width of 1 sheet foamboard) with an Emax 2800 kv motor, 1000mah 2cell and 6x4 prop. I haven't flown this one yet, but I flew the snot of the the first FT F22 with the same setup. I might try it with a 7 inch prop just to see what happens.
Rick, I flew my 75% indoors at NEF. I was a handful! David helped me out with the throws, I didn't have them moving enough for flying inside. I'm still a beginner/intermediate pilot so I only did a couple laps and then landed.
I did fly it outside yesterday and it was a rocketship! I have a suppo 1450 and 7x5 prop powered by a 800mah 3s. It rips! I can't wait for the weather to get better and less windy of a day.
Lets us know how it goes.
EODPete
image.jpg image.jpg image.jpg my two FT22
dwardio
Maiden flight of my FT-22
Finally managed to maiden my FT-22 today. It flew pretty well, but the motor mount came loose from the foam at landing. BTW, I installed the Orange 3-axis rx, and the stabilization was great!
zjguy721
I'm thinking of building one of these as an indoor flyer. Thinking of about a 16" wingspan (about 63%) and a profile fuselage. Anyone built one like this? Haven't seen any build threads like it. Flying in a single court gymnasium, so space is tight.
Using this motor: http://www.hobbyking.com/hobbyking/store/__8613__Turnigy_1811_Brushless_Motor_2000kv.html
GWS 5030 prop, 2S 260mAh battery with a 10A ESC. As long as I keep it around 100g it'll go vertical. I used this same setup on a Yak 3D setup, but I don't have enough wing area and it's really twitchy indoors. Figured if I'm starting from scratch on the airframe, this might be a tamer flyer.
docd
Hey guys, so this is my first scratch build...
I bought some foamboard at walmart, but didn't pick up enough, so I decided to go with cardboard. I haven't got any of the electronics yet and I'm already at 430g. Is this going to work or should I just start over later? lol
makattack
Winter is coming
docd, now that is re-use! Nice! I really hope you try to get it to fly. At least tape/set the elevons with "up reflex" of a few degrees, and give it a good hard toss towards grass! The FT-22 should glide pretty good without electronics, even a cardboard build!
How many knife blades did you go through to cut all that out?!
Jaxx
I think it's worth a shot. Do a glide test and see how she glides. What do you have to lose right?
docd
Never really thought of that... I'll give it a shot tomorrow, if it doesn't snow XD
I cut it out with the first blade on a cheap box-cutter. Actually, its in that picture: next to the pencil in the upper left. It's about the same sharpness as a rusty butter knife now lol.
Update: I taped the elevons up and threw it around a little: actually glides surprisingly well!
New questions:
1. Considering her portly state, minus any of the junk that would make her capable of powered flight, she's 430g, will the recommended motor still be powerful enough?
2. What would you recommend for a transmitter with elevon mixing, bearing in mind my cheapness?
Labersin
Hi builders.
I'm building the F-22 for the first time and i'm making it out of 1 large bit of foamboard (48x36"). On the video of the speedbuild kit, the foamboard of the wing area is folded in half with for packaging (i assume). My question is, I assume leaving it whole and not cutting it will be stronger than cutting and hot-gluing it (as i don't have any CF to put in right now anyway)? Its late here (11:46pm) so my brain isnt working at 100% and i may be waaay overthinking (or underthinking as the case may be) this.
Cheers.
-Sean
