Center of Gravity, it's usually referred to as CG, but both ways are accepted.Hi guys.
Great looking plane. I might have missed something in this thread but i still need to ask, whats the COG?
What a great design! My son and I built the first F22 3-ish years ago after seeing it done by the Flitetest crew.... every flight the nose came back looking like an accordian :black_eyed:
It's been a few years, and a few planes since, but I couldn't wait to get my hands on these plans. Absolutely perfect timing as my son now turns 14 on Tuesday, and I built this for him! He'll be thrilled. Thank you Josh and FT team!
If you're going to answer all your own questions, you make our job that much easier!Ordered my kit, now ready to calc my power system...
Can anyone provide me the full-up weight with a 26g motor and 1300 3S?
Thanks!
Update: Found it on the plans (duh!)-- 8.3 oz w/o batt.
What paint did you use? it looks great by the way!
I felt the need for SPEED!
2826-6 with a 4.5x5.5 prop, on a 4s 2000mah lipo. Screaming fast, but with a 10-15 min. mixed flight duration. It still floats in for landing power off, and at a 125mph pitch speed, it moves out! I'm guessing 110 MPH easily. Or, I can also fly with a 6x3 prop on 3 cells, and do some aerobatics no problem.
Great design Flitetest, it flies awesome!
I had a brief glitch at 1000' range and piled her in at around 90-95 mph. She was flying 5 min later.
Bolvon, I didn't even glue the nose on! How did yours come off?
This has to be the most precise foamy I have ever flown, even sans cockpit (cooling). I just fly it at WOT 2' off the deck most of the time. Unfortunately I did find the only bush in the field and damaged my right wing and fuse. It's still flyable, but I'm building another.
Ugh, v2 is under construction. V1 "landed" in a rocky area at around 90 MPH due to a radio lockout. I was using a slightly problematic Receiver which got more glitchy as the day went on. I was performing a high speed low altitude pass when it stopped responding, and slowly lost altitude and pancaked. I ripped the belly pan in half, crushed the nose, sheared the right wing off, and broke the prop. Not bad considering I landed at a scale speed of over Mach 1.![]()
