@BATTLEAXE Thanks! Do you have a list or pics of the other mods? I'm thinking of creating plans with some of the mods incorporated. Sorf of an unofficial F-22 v2.0.
Yea I do
I leaned in the side walls for the intakes to have a F-22 profile, they did have to move out a little near the slot to fit the lean in but not noticeable compared to the original, maybe a few mm's
The walls are also taller to bring the wing up the fuse closer to line of thrust, plus it looks more scale.
In one version I tapered the nose in on the sides...
Then I went all out and just used the nose from the STEM Series at 122% upscale to complete the look of the diamond profile of the cockpit and nose area on the last version. If you take a look closely at the elevon hinge line, you can see it crosses in front of the motor and turns 90 degrees into a cut through to make almost a stabilizer. You can see it on the last.
Plus the top mounted pull to positive servos
This one flew the best, faster and more responsive. There were a couple of other small mods to the pod to fit larger motors.
Here is a vid if this helps
