Got up early to maiden the FT3D, she handles great, but a 3D pilot I am not. just some loops, rolls, and inverted for this flight. Still a lot of fun.
Thanks Josh, Chad Aaron and all involved for all the work to make these builds so easy.
(Edit) A couple of alibis on my build process, lacking a source for balsa within 45 miles I used pine lattice cut to fit for the spar, worked great, just a couple of grams heavier. It did not affect the flight. 1 inch by 10. I also had some difficulty with the mounting of the second wing. I put the hot glue between the foam spars before sliding it in, which softened them and made it very difficult to run them into the fuse. If, as I am prone to do, destroy this one, I will put the glue directly on the wood spar then slide it on. I probably used too much glue. Other than that, went together great and taught me a lot of new techniques.
