I just finished building my FT 3D and I have a few points to make about the video instructions.
1.) You mentioned in a newer video that you shortened the servo rods. In the build video you show the aileron servo installed with the motor part facing the front of the plane. However, the shorter rods will not reach and the servo needs to be installed the other way.
2.) The kit needs 2 popsicle sticks, mine only came with 1.
3.) In the video you leave out how to glue the tail parts to the frame.
4.) I'm guessing this is because my glue gun isn't hot enough, but when you glue the second wing on and use the glue as a lubricant, mine only lasted about 2 seconds before hardening. I was able to peel it off and go again with less glue.
5.) I'm not sure how to mount the VGs on the wings. Do i just cut slots in the wings, use some glue and press them in?
6.) The cockpit piece doesn't have A and B on it to designate fold types and I think in the video you say the wrong fold to make, you'll have to check on this but I did it wrong the first time and had to redo it.
All in all it was a fun build, i'm about to go destro..... fly it!
