FT Alpha newbie
CapnBry
Something definitely seems out of whack. On my BR2205 2300KV motor, it will do a 6x4 prop and generate 550g of thrust at 14A. That's 3.6 minutes of full throttle on an 850mAh. 70% throttle is 6.6A or 7.7 minutes. I know the slot creates some extra drag on the prop not not twice the power. A 6x3 prop drops max power down to 12A and only 520g of thrust, so that could help your situation but not by much. Seems like the motor is pulling an abnormal amount of power to run. Did you check to make sure the motor bell isn't rubbing against something and slowing it down, or maybe the center hole in the firewall isn't wide enough for the motor shaft to not rub and pull extra power?
WasabiRC
Hi there.
Thanks for the reply.
I’m pulling 21A at full throttle and 260W. Don’t know how much thrust it giving though. I did check the hole in the firewall but will strip it tomorrow and double check. The bell is definitely free. Screws are also not touching anything.
It’s very strange.
