Hi!
I have fallen for the Bloody Wonder and now built two of them, slightly modifying the second one in an attempt to get better performance, bigger motor, prop and battery.
Even if they have flown very nicely I have one problem. Both planes is pulling up when adding more thrust. So if I give full throttle and don't compensate with elevator the will do a loop. It's alright to fly as long as you counter it with down elevator.
The question is if there is a easy enough fix when building another Bloody Wonder like angling the engine downwards, or angling the whole body in comparison to the wing. Or if it's the tail section that might not be aligned perfectly with the wing. Any suggestions are welcome, thanks!
And yes, I need to build another one since my second one disintegrated on "landing" Totally a pilot-error, no excuses
