I built them 6 months ago, but I finally got a chance to give my Bloody Wonder a maiden flight, along with the maiden flight of my FT Delta.
I didn't know what to expect on the Bloody Wonder since I modified it a bit from the FT plan (notice the extension on the nose). I also didn't use the airfoil design from FT and instead went with the standard Bloody flat top/bottom.
Throws were set up about "medium", and I used my old Spektrum 4 channel since I'm having some issues with my ER9x or the Orange module. No expo for me! For the first flights of both planes I went light-weight. No landing gear and 2S 500mAh batteries with a slow-fly prop.
I was completely amazed with both designs and how well they flew! Both were very docile and easy to fly with this setup, although I'd consider both of them under-powered as well. Limited vertical travel and somewhat sluggish, but for the maiden flights that is what I wanted. Flight times with the 500mAh packs were around 4:30 to 5:00 minutes.
I had a 3S 1000mAh pack with about 75% left on it after flying a different plane so I put it on the Bloody Wonder to see what difference the extra power would make. It certainly helped performance, but the extra weight also made it extremely responsive to down elevator. It still glides well, but tell it to go down and it goes down FAST!
Now that I know both fly well I'll spend some time checking a few different props to see if I can get better performance with the 2S. I don't want the extra weight of the 3S 1000mAh if I can avoid it - maybe I'll pick up some 3S in the 750mAh range if needed.
The combination I have now would work great with the NutBall or FT Flyer. I still need to maiden the NutBall I built a while back - this should be a fun setup for it.
Here are the planes taken out for some fun today: Bixler 1.1, FT Bloody Wonder, FT Delta, Red Swan (HK balsa glider kit), Mountain Models Switchback Sport, and the Hobby Zone Super Cub.
