I noticed you mentioned adding weight to move the CG. Most pilots just move the battery to adjust the CG so you're using what you have to have on the plane, and not adding what amounts to dead weight.
Good catch Xuzme!
Trafficked,
My motor is heavier, but the natural balance (w/o battery) should be slightly forward of the recomended CG -- adding the battery around 1/4 to 1/2 over the CG should move it back to the sweet spot. Otherwise, space gets pretty tight in the front of the pod for a battery and ESC, especially a 4S.
Would be a shame to need an extra 1/2 oz of ballast for no benefit other than CG . . .
