When Josh does his bevels the blade just glides along uniformly and the cut off piece falls off in a nice smooth perfect strip. When I do them even with a brand new #11 exacto or a new single edge razor blade, the paper argues, the foam balls up, and it looks like a dog's breakfast. So technique is obviously going to play a role, also will have to sharpen or replace blades at a ridiculous rate, have one of those scissors sharpeners around somewhere.
Today's lesson was also that mini glue guns cannot output enough hot glue fast enough to make a good Wonder wing, by the time the bead has been run on the spar the trailing edge glue is setting up. And this was a high temp mini, the low temp was ridiculous in lacking working time. Oh well, grab a big one and do another, it's not like the foam was expensive. The wing is likely usable it's just not pretty, I may finish a build with this wing and fly it banzai style abusive. The ugly one won't be getting masking and paint.
