Hey,
Finished building my blunt nose versa. What motor should I use?
I want a motor giving me fast performance and long flight times.
I am planning to use a 10x7 prop. I have checked the cg without any electronics mounted (servos doesn't count) and it's sooo tail heavy.
I tried placing 2 3s 2200 in the front but it was still tail heavy!!
Is this normal?
With a big motor in the back, it will be even more tail heavy meaning I will need to use an even bigger battery in the front!
Do you place alot of extra weight in the front or do you just use an enormous battery instead?
thanks!
Is this normal?
thanks!
