Properly set up and trimmed, it is only slightly positive stable upright as an OV10 lookalike. Set to the appropriate throws, it is a point and goes there immediately plane, but it won't turn or climb for the fence in the way without finessed control input.(neutral stable) Responds nicely to stick slapping but dont expect it to fly inverted much, or go back to straight and level on its own. Likes to turn left with both props being the same RH rotation.
Does a really.good.ugly. when you full down and full left or right stick.
40+ years ago there were discussions about semi advanced planes used for trainers, but they all defaulted to having a very skilled friend on a buddy box system to save ones bacon or plane.
One could change it to be a stable trainer, but then it would look cartoonish ALA
@Silver Surfer FPV. My opinion is it needs to double the diehederal and add a couple clicks up elevator and loose a pot load of weight, then limit throws. Your mileage may vary. A twin "C" motor pack is very much akin to model rocketry including vertical take off
NET RESULTS:
lousy trainer
