SSgt Duramax
I think it looks better with the longer nose.
I have started this thing when I design planes to make sure the nose is long, and maybe longer than it needs to be. It is always easy to scoot the battery back. Squeezing it forward millimeters away from the prop is no fun and usually doesn't fix the issue.
I also echo the sentiments of not using hot glue on the tail, I haven't used it back there in quite a while. I have typically opted for wood glue.
Also, while we do focus a ton on the tail (and for good reason) I have learned in my plane 3D printing time that wing weight behind the spar/balance mark matters a ton too. I kept wondering why one of my planes was so dang tail heavy, did some quick math and figured that my battery should have easily been able to balance the tail weight out, and then I picked up the wing, which was probably the heaviest part of the plane, and it was super tail heavy. Now I know the moment around the center of gravity is less, but still it adds up, especially if you are glooping your wing with hot glue when you put it together. Something worth thinking about when you are considering reinforcement placement, servo placement, or wing construction techniques/materials in general. While it may not be as huge as a heavily braced 3D printed wing, it still counts and is worth considering.
I think a lot of us on here use Ender 3s, pretty much because it is a widely used and very well supported budget printer with readily available parts and support. There are absolutely better printers, there are cheaper printers, and there are probably arguably better ones for the money, but it is kind of like the easy button for printers under $300 bucks for people that have never done 3D printing before and aren't sure if they want to dump a huge investment into one. It is to printers as the FS i6 is to radios. Once you outgrow it you will know what you want.
There is no right answer, and folks will have varying opinions, and a lot of your success will come from your willingness to fine tune and learn about the thing, which could really be said about any printer. Some will be harder or less capable than others. The Ender is just the right amount of easiness and right amount of capability for the right price for a beginner. But I am no pro.
I do not have a 3D printer yet, but plan on buying one in the next month. What printer do you have or would recommend that won't break the bank but is still easy to use without much problems?
Yes, please send me the STl files for all that you mentioned including the Tricycle gear. Thank you!!!
If you have any sweet ideas for a parachute drop that would be great too.
I think once I get a calm day I might actually get this Bushwacker to stay in the air. I have launched it a couple of times but crashed soon after. One of these times I will get it back on the ground safely. Ha Ha.
