not to be critical but you use WAY too much hot glue.
i like my Edge but i never have seemed to be able to find that sweet spot on motor, prop, battery combo. it is fun but if i want to fly 3D i have much better planes to choose from.
laters,
me![]()
The hot glue issue is because I struggled with the motor mount. It will be fine.
I'm using the suggested Power Pack C. I trust that it will be fine.
what prop and battery do you plan to use?
me![]()
Watch your motor temperatures - I burned up one of the radial C motors on a 4s and 10x7 prop.10×4.5 prop. 4S 1300mAh.
That gives it a really nice look, I like it. I see you use turnigy esc's - those are great esc's!While I was off I finished painting the motor bay and power pod, also painted the inside of the nose grey.
View attachment 195216 View attachment 195215
I am running an Emax GT2812/09 1060kv, 3s 200mAh battery and a 12x6 prop
The 5a BEC is one of my favorite parts about it for sure, it's so nice not worrying about using an external bec when using more than 4 servos.Yes that's well spotted, I like the Turnigy plush-32 series the 40amp I have installed has a decent size SBEC - 5amp. It saves fitting a separate BEC, particularly as I am fitting digital metal gear servos.
I don't bother fitting cheap ESC's on decent planes anymore, its not worth losing a model over a few extra ££££, or $$$$ in your case.
Flite Test always used Emax motors in the beginning, that was until the new radials came on the scene (the only advantage over Emax they can run on 4s).Nice! I'm sticking with the FT recommended power pack. Their products have never steered me wrong.
I found that the radial C motors have noticeably more power than the old emax C pack motors.Flite Test always used Emax motors in the beginning, that was until the new radials came on the scene (the only advantage over Emax they can run on 4s).
I regularly use the Emax motors particularly the GT2215/09 1180kv motors, they have plenty of power and as nearly all my batteries are 3s they more convenient.
I have got one Emax that runs on 4s 5000 mAh pack, the GT3520/05 925kv. It powers my balsa WOT trainer which weighs in at 2kg, but will go vertical with this motor and will also fly for a good 12 minutes if I am sensible with the throttle.
I did actually run my emax c packs on 4s with a 9x6 prop and it worked well. 🤫🤫(the only advantage over Emax they can run on 4s).
Thats one neat nose! Is it scratchbuilt or are u using the kit?Just finished off a couple of jobs on mine tonight, the vertical and horizontal stabs have hinges fitted and the edges prepared and sealed.
I have also mounted the front cowl. It was a relief when it was finally secured in place, as it was a pain in the arse to construct and assemble from a plan. Although it was not quite as bad as the rear turtle deck, that took 3 attempts to get right. My foamboard just doesn't like to bend even with heat backing paper removed and working with the grain.
View attachment 195229 View attachment 195230 View attachment 195231 View attachment 195232
Tomorrow night is filler (spackle) night, plus sanding and more filler. I also need to fit the side supports inside the cover and finish off the cockpit.
