Hello everyone,
As I was building my Ft Explorer, I discovered a couple problems.
Problem 1: The propeller (C Pack) was swinging against the tail (Photo 1). When making the motor pod, there was a bit of space between the top and the motor (Photo 2). I am assuming this is the problem, but how can I fix the problem? What are some ways to remove the hot glue easily, so I can redo the Power Pod?
Problem 2: The propeller isn’t going all the way into the motor shaft (Photo 3). When I tested the motor with the propeller (without the tail), the propeller quickly flew off the shaft. How do I insert the propeller correctly to prevent this?
