Hi
@alan0043, welcome again to the forums. This is your thread and I kinda took over lol. I am just as excited about tis Explorer Idea as you are. I was just given an Explorer already built and set up to play with and I will be modifying it to be more like the Bronco with the twin boom. I will tell you the Explorer is an awesome plane to train with. In my past flight experiences with both the Tiny Trainer and recently the Explorer I will tell you that I think the Explorer is a better trainer then the TT for a few reasons. Now some will say otherwise, there are some TT purists out here, which is great, it works for them. But for me and since your looking at doing the Explorer i find that because it is a pusher prop you will be breaking a lot less props then on the TT from nose in crashes, and if you do crash all you need to build is a nose piece as opposed to a nose and power pod. Plus the added bonus of protecting your electronics and motor from impact damage. Its also a bigger plane so it will be more stable in flight in even stronger winds where the TT being a smaller airframe will get wonky with less then favourable weather. I am a big fan of the Explorer can you tell? Plus if you set it up as a 4 channel it will grow with you as you progress in skill set, just dial back your throws and expos to begin with and it will be a docile plane, as you get more comfortable you can dial them back up to tighten up the control and keep movin up the piloting ladder. I have been through a lot of planes when I started just because they looked cool but were to fast or twitchy for my skill level. I should have started with the Explorer to begin with and my skills would be so much better now. It's like I now have the opportunity to re learn how to fly lol.
Did you build the TT from a Speed Build KIt? What power system are you using in it?
Have you looked at the Bronco yet? Because it is the same airframe as the Explorer but with the twin boom design. Actually it's does have a smaller faster wing so it will be a bit more advanced then the Explorer as far as skill level. I would say build the Explorer airframe and wing, and if you want the twin boom design add that to the wing you already have, gives yo the best of both worlds.
Since you have the TT built and you are into the gliding thing, try chuck gliding it, throw it off a hill into the wind and test its balance. once you do that a dozen times set it up for powered flight with all the control surfaces working and plugged in with the battery, but no prop. Chuck glide it again but try to control its flight in the glide. Once you see results there, install the prop and try powered flight. This progression will help you understand the planes characteristics and your piloting progression as well. If you find that you are having trouble get back on the forums here and ask any questions you like, anyone will be more the willing to help you out.
Good luck my friend
P.S. I am so jealous of your proximity to Edgewater, I so want to check it out sometime
