FT EZ Receiver for 3Ch Build
dmco
New guy here, my boys and I have built several of the 2Ch EZ Flyers and they are great fun. Now I would like to build some of the 3 channel EZ plans I am finding, for example an EZ KrakYak with servo. But FT no longer sells the 3Ch kit. I have the FT 2Ch kit, and looking at the GD00X protocol channel assignment, could I use CH6 to control a servo? Does anyone have a link for the servo that used to come in the 3Ch kit (or similar)?
BadAir
I keep thinking you should be able to use a magnetic micro servo. It wouldn't be much and would be on or off, but it couldn't hurt.
Polarity 1 = right rudder
Off = Neutral
Polarity 2 = left rudder
How to swap polarity? I can think of some ways, but it might be better to use the motor differential and power a coil either side of the rudder according to how much juice the corresponding motor is getting.
I believe those ports there are for the lights...So don't think it would work to control a servo because you want that to be variable...Though you can find the 3 Ch ft kits on eBay sometimes.
dmco
Great info and ideas, thanks! In my quest for 3+ Ch receivers, I found the AR3201 which looks promising:
I also found cheaper single-motor receiver/ESC combos that might work, but figured a twin would be easier to retrofit to FT EZ style aircraft.
BadAir
Post it up. I'm always looking for stuff for my students to use.
dmco
BadAir, for single-motor, was finding stuff like this around the $15 price point:
Upon closer inspection, that might be lacking a receiver?
But I am too impatient to wait for shipping from China. It seems Buzzard Models is a good US-based distributor for the Crossover-RX stuff, so I have an AR3201G and some servos on the way to experiment with.
My goal is to build an EZ raptor with at least one servo, or maybe an EZ Crack Yak style with elevator and rudder.
dmco
@LitterBug that is a great idea, I hadn't thought of that. Only problem is the FT EZ receiver using that weird GD00X protocol. But maybe the 2nd receiver could use ELRS, assuming the transmitter had multiple modules installed. If I can't get the AR3201G working, I might try that route.
I found a few micro 1S FrSky RXes on clearance a few years back. They have the nano linear servo plugs on the pwm ports. I also have external FrSky XJT and spektrum transmitter modules for dual binding with different protocols.
dmco
Here is what the AR3201G looks like next to the FT EZ motors (connectors are a direct fit). Haven't weighed everything yet, but these 15320S servos are supposedly 1.7g each. The receiver is actually smaller than the FT EZ receiver. So I am hopeful this might be a good fit to add 1 or 2 servos to some EZ-style planes. When I have time, I am going to try building an EZ Krak Yak and see how it goes.
AIRFORGE
Make It Fly!
FishbonesAir
Ancient thread, but right up my alley. Buzzardmodels.com is great, and I'm a repeat customer.
The tiny Rx he sells are available in multiple protocols. I use FlySky, many use Spektrum. There's others too.
He has motors too, and some of the Rx have built in ESC, either brushed or brushless. One has dual brushed and one supports 2s brushless.
