Will you be releasing DXFs as well as PDFs? Sure, I can release DXFs for this.
SP0NZ FT CAD Gremlin Staff member Admin Moderator Mentor May 14, 2020 #41 Michael763 said: Will you be releasing DXFs as well as PDFs? Click to expand... Sure, I can release DXFs for this.
Aviator08 Flagstaff,AZ May 16, 2020 #42 Fight tested the EZ glider... It works! CG = 1 1/4" back from leading edge of wing next to the fuselage. Use high rates. Attachments Glider EZ.dxf 28.6 KB · Views: 0 EZ glider.pdf 3.1 KB · Views: 0 Last edited: May 22, 2020
Aviator08 Flagstaff,AZ May 16, 2020 #43 Next one.... It flys also. V1.1 - fixed some structural issues. Flys good in little to no wind. CG = 1” back from leading edge. Use high rates. Version 1 Attachments A-10 EZ.dxf 44.5 KB · Views: 0 A-10 EZ.pdf 4.3 KB · Views: 0 Last edited: May 26, 2020
Mr.Grinch Well-known member May 16, 2020 #44 I really like that glider, I think that’ll be the first one I’ll make when my kit arrives.
Aviator08 Flagstaff,AZ May 16, 2020 #45 spdxdmn said: I really like that glider, I think that’ll be the first one I’ll make when my kit arrives. Click to expand... Thanks,
Aviator08 Flagstaff,AZ May 16, 2020 #46 Next one..... also unflown do to the wind. Attachments Bipe EZ.dxf 56.6 KB · Views: 0 Bipe EZ.pdf 5.2 KB · Views: 0
A alan0043 Elite member May 17, 2020 #47 Aviator08 said: Fight tested the EZ glider... It works! View attachment 169109 Click to expand... Hi Aviator, Question for you. Does the main wing have dihedral ? Thanks, Al
Aviator08 Flagstaff,AZ May 17, 2020 #48 alan0043 said: Hi Aviator, Question for you. Does the main wing have dihedral ? Thanks, Al Click to expand... Hi Al, Yes it does. About an inch, maybe just a tad more.
Aviator08 Flagstaff,AZ May 17, 2020 #49 I know, I know..... I'm dreaming again. with 30mph winds this week I don't think I will get to try it soon. Attachments Wing EZ.dxf 20 KB · Views: 0
mrjdstewart Legendary member May 17, 2020 #50 ok, so explain the trick for making it switch from a pusher config to a tractor? do you get diff props? or plug in diff? mine will be arriving in the mail tomorrow and want to start making some of these. thanks, me
Aviator08 Flagstaff,AZ May 17, 2020 #51 mrjdstewart said: ok, so explain the trick for making it switch from a pusher config to a tractor? do you get diff props? or plug in diff? mine will be arriving in the mail tomorrow and want to start making some of these. thanks, me Click to expand... I was planning on using the motors on the same side as in the pusher configuration and just flipping the prop over. Haven’t tried it yet though.
The Hangar Fly harder! Mentor May 17, 2020 #52 Is there any reason why all the FT designs are pushers?
mrjdstewart Legendary member May 17, 2020 #53 well @SP0NZ designed a tractor so i assume it is possible.
SP0NZ FT CAD Gremlin Staff member Admin Moderator Mentor May 17, 2020 #54 Tractor works fine. The trick is swapping and flipping the props. Not sure why all the ones Josh designed are pushers.
mrjdstewart Legendary member May 17, 2020 #55 SP0NZ said: Tractor works fine. The trick is swapping and flipping the props. Not sure why all the ones Josh designed are pushers. Click to expand... perfect, thank you! me
mrjdstewart Legendary member May 17, 2020 #56 what are we saying for an optimal weight? how many grams before it becomes a brick? again, thanks. me
AIRFORGE Make It Fly! Moderator May 18, 2020 #57 SP0NZ said: Not sure why all the ones Josh designed are pushers. Click to expand... I'm thinking it might reduce prop damage, having something between the props, and the inevitable.
The Hangar Fly harder! Mentor May 18, 2020 #58 Addicted said: I'm thinking it might reduce prop damage, having something between the props, and the inevitable. Click to expand... Yeah, that's what I was assuming. Do you know if you can get replacement props?
The Hangar Fly harder! Mentor May 18, 2020 #59 Also, it seems pretty hard to break a prop on it. I mean you can hit a tree, wall, or something but no nose dives!
AIRFORGE Make It Fly! Moderator May 18, 2020 #60 The Hangar said: Yeah, that's what I was assuming. Do you know if you can get replacement props? Click to expand... Good question! I haven't looked for, or even thought about replacement props.
