flightlover210
Hello!
I have been flying my ft flyer for a couple weeks now and can not seem to fix a problem I am having. I would not describe it myself as being stable how Josh Scott described it in the ft delta video.
Here's the problem:
If I let the nose down any more than twenty or thirty degrees for longer than a second, it goes rather violently into an outside loop and ends up inverted, and gets stuck for a couple seconds until the dihedral rolls it back over. I have played it with the cg quite a bit and have it in a place where it flies horizontally without much input on the elevator. I read that the cg is right when you trim it level, then it can glide at 45 degrees without changing pitch, so I tried moving the cg back until it is essentially a helicopter, and up until that point, it has always had the problem. The only way to recover it to give it full up, but then it usually stalls a tad.
Any help would be greatly appreciated. I am thinking about putting on a kf2 to see if that will help to see if that might work.
thanks
Here's the problem:
thanks
