FT Flyer weight ( updated )
I just built the FT Flyer exactly from the plans. It looks really nice. But the weight is 315 grams incl powerpod electronics landing gear etc. But without the battery. Seems heavy to me. I used 5mm foam board from the Netherlands (peter van ginkel). Also the CG is 1cm behind the CG from the plans. I can make it heavier in the front to move it. Will that be neccesary.
I have the 2s 500 and the 3s 500 and an 2s 850 and used the recommended electronics from the website. Turnigy park 300 1380kv , 8 x 4 prop.
I have experience with a parkzone radian and enough simulator exp. Will the weight be a problem? Do I need to lose the weight before the maiden?
Thanks in advance
P.s. love the show
EDIT: It worked perfectly ! the seemingly heavy foamboard from the Netherlands is good with the designs. and the recommended electronics. Although 2S is almost to slow. So go with the 3S batteries. used 500 and 850.
Thanks in advance
P.s. love the show
