In digging around in my tickle trunk, (you older folks know what the tickle trunk is), I found the power pod I used on the Spear so I improvised and Mcgyvored a pod system for the Gobby
This was salvaged from the 80% Spear, forgot I had it
Built an indexing system for it, I cut a relief in the back of the wing in the fuse, notice the notches that take the skewers in the front of the pod over the wing. There are also skewers to hold the top of the pod just the same as most FT designs...
BAM! we have a power pod for the Goblin, copy cheat and steal if you like.
Now to cover the bottom, all the airflow will be coming from an opening in the bottom under the wing allowing access to the ESC. Rx will be up on the deck of the fuse and battery will be strapped underneath inside the nose. Did it, I should have been an engineer
