On a related note, Keegan was flying the NightHawk 280 today (only his 4th or 5th flight); he put it in acro mode and did some flips with it already. Kid can fly circles around his old man.
Well done, SPONZ.
I got the emax BabyHawk flying. What a great sense of accomplishment. One step closer to getting the Gremlin built. Learning a lot so far and loving every minute of the journey.
I seriously advise NO coffee during the build. If you are anything like me you will be shaky enough trying to solder under all that magification needed to even see the pads hehe.
Good luck and watch your heat on this build as it is pretty critical.
Did you test and flash everything at this point? It would be a good idea to do so now if you did not. You also need to think what protocol you wish to use. The esc's use different firmware for the various protocols. 16.0 (or any .0) is for the one shots and 16.5 (or any .5) is for multishot. The Femto is capable of Dshot but usually requires remapping motor assignments and also only uses Dshot 300 which is actually slower then Multishot.
Oh you are in for a treat then.. Might wanna meditate before starting. This can be the most frustrating part of any quad build as sometimes normal process works. Others not so much. I wont toss in scenarios to confuse you but can answer questions as they arise if needed.
All the various "shots" are esc programming variants that have progressed over time. Mainly due to the speeds and precision they can control the motors with. Earlier ones are the "Oneshot" series then came "Multishot" which was faster and added more features like active braking I believe? Then came "Dshot" which is a digital protocol not analog which is even more accurate and faster and does not require any calibrations to work properly like the previous analog esc protocols do. There are now four levels of Dshot and the two levels the Femto is capable of using are actually slower then multishot so that is one of the trade offs for the more smooth protocol. For the Gremlin faster is better then smoother being as small and nimble as it is IMO.
