Geronimo
Hi guys, I took the (nearly) finished Spitfire for a maiden today and found the controls seemed too extreme. I built the kit using the build video so I'm assuming the control throws are in the ball park. I did not put any expo in before the flight, and now I have 30% for all 3 AE&R.
But what should the throw angles be set at? I never see anything discussed about this. My current throws are 22 degrees for the ailerons and 25 degrees for the elevator (I measured them very accurately).
Also, for the ailerons, I'm assuming that because of the flat bottom airfoil the aileron should go up more than down, which is easy to adjust via the servo arm.
Thank you!
Thank you!
