If you hold the bird in the hand vertically on full throttle, do you have the feeling that it could lift itself up?
edit: I looked at the big version of the pic (thanks for the tip btw. clicking on it multiple times was the trick as I was not bale to zoom in after the first click).
Just to clarify things up. In my understanding, the motor is spinning ccw if the the prop is spinning ccw from the view of the pilot. Please correct me if Im wrong here.
Assuming your prop is running ccw, Im pretty sure that the motor angle is wrong. Again it is hard too see on the picture and easier to check for you but for a ccw spinning prop the motor angle must be to the left and not right.
Anyhow, make the vertical pull test. If this shows that the plane has the power, it has to be something with the pod as the build is nice and clean and I doubt that aerodynamics are off in any way. Maybe you can upload a photo of the unmounted power pod?
