I too wish to extoll the virtues of the FT mini mustang.
I've had the kit since last summer, but only got around to building it a few weeks ago.
And a different angle:
It flies so well! I'm so happy with it. Actually, the first time I threw it, it was a bad throw and I crashed it. But a little hot glue, and I got it into the air.
The bright asymmetric paint job is a real lifesaver. My 53yo eyes aren't what they were, and the plane is small, so it really helps with perspective. I built it without rudder control; I'm happy to yank-n-bank. What I also like about the mini planes is they don't mind a hard landing.
I've collected a variety of batteries, and to my delight, the mustang flies with almost all of them! I've got an 1806 motor, 6x3 prop, and 12amp SC (so, an A pack), and I've found my mustang can fly with a 400mah 2s, all the way to a 1000mah 3s. There's a cavity right under the motor for the small batteries to fit into, and the fuse is cramped when I put the 1000 3s in, but it all works. I would imagine that, for this motor, an 850mah 3s battery would be perfect, and you could probably get amazing vertical with a 650 3s.
Did I mention it flies well? I really had to dial down the aileron throws, and I'm happy using 50% expo. Also, the wing tips seem to want to get banged up and delaminate. A little tape fixes that. When I build another one, I'll do the Josh method of sealing the wing edges with smeared hot glue.
I was enjoying myself so much, but then CRASH!
Pilot error. Remember, kids, when you're too low and too excited, a split-s is a split-end.
