Mini Cargo bay and bottom mounted door servo
After some flights with my first Guinea, a speed build kit, I decided to build a second fuselage to implement some mods.
Before even building the Guinea I wanted to drop stuff from it, having built a opening door on the first attempt and in talking with my friend who also built one, he mentioned partitioning off the cargo bay. I sketched up some plans for a isolated cargo bay, built one fit tested it, then tweaked the design. Cargo bay build 2 worked out better, I cut it out of black foam board (Adams).I designed it to go forward in the haul a little, leave room in the top of the fuselage for the tail servo wires, and the rear wall of the cargo bay is positioned to stop the door from going up into the haul.
Because of the cargo bay I had to move the door servo/linkage. I decided to locate the servo in the bottom of the fuselage and then position the control horn on the bottom of the door. I had to position the servo far enough forward to be ahead of the cargo bay and also decided to center it left/right for CG consideration. I cut a hole a large enough to fit the servo and allow control arm movement. I then cut a piece of foam board a little larger than that hole, cut a notch out for the servo wire, and then glued it to the inside of the fuselage. I positioned the main gear on the door hinge line so that the door control horn could pivot over the axle. Since the servo sticks down below the bottom of the fuselage I added a piece of foam board cut into a U-shape and beveled the leading edge and sides. The video below shows the door movement, still run on the flaps setup on my Spektrum DX6, I currently have the mid position set just below level with the bottom of the fuselage and the full open is just about where the control horn is close to hitting the axle. Once I build another nose, my original nose lived a noble life and died a valiant death, I plan to make the mid position open to the ground like a loading ramp.
I will post up the plans for the cargo bay once I clean them up a bit.
