High Flyers,
The wind was starting to come up so I only tried a little with full throws. It would loop and roll quickly. This is new territory for me so I was cautious. I could not get it to flat spin but I was pretty chicken and have lived to tell the tale.I have no wheels but love how the wide body lands on grass. Very gentle. Nice!!!
WHAT A FUN PLANE,
Thanks Flite Test,
LooseBruce View attachment 44244
I fly from a hay field and SOP is to cut the power and glide in to a landing.This plane glides very well.You are correct, the plane flies really great, no tip stalls, and it can almost float in with no power for landings. Definitely a very stable flying plane.
Since I was flying at a small fraction of full throttle I have switched to 2200mAh 2S batteries. I still have more than enough power for my style of flying. I am using some Thimble Drome 6 X 4 props now because I broke one of my 5 inchers.Went out again tonight for two 8 minute flights. It felt so stable that I tried multiple loops and rolls. The rolls still need some work but 3 loops in a row were easy as pie!!
finally I set the throws for the center of the sun (100%). YES!!! it will flat spin!!!. Not exactly like the Flite Test guys spin but definitely violent and out of control like a satellite shot out of the sky with a laser.It is kinda like a goofy wiffle ball. It is just amazing what it does. And the recovery worked also!!! Ya gotta love that.
A really FUN plane. Now I gotta drop something.
LooseBruce
I have enjoyed my MG so much I decided to make a miniMG (75% of the Mini Guinea) too.
The MicroGuinea
Also i see that you have horizontal stab "flexing" problems too
This is one FUN airplane!!
Thanks Flite Test.
Well I finally had a serious problem with my Mini Guinea. I have crashed it several times and did appropriate repairs. It was getting fairly "soft" all over. Especially the wing tips and the tail areas.The other day I was flying as a front was moving in (when will I ever learn?). Not too windy on the ground but I was getting tossed around in the air. I just couldn't get it under control well. I was looping up and to one side when I applied throttle. This sent me downwind at great speed.I think if I had the 3S batteries I MAY have been able to penetrate the wind better but control was a major issue in any case.
I found the problem that caused some previous crashes and the final crash. I put the servos in my new wing. At one point the aileron servo which had been noisy rotated all the way in one direction and "locked " in that position.This would cause exactly the flight response I was getting. I am sure this is what caused the crashes. I freed it up and forced in back into position. I worked for a little while and then locked up again. It is being replaced. I should have done it sooner. When I am going to stop learning things the hard way?
LooseBruce
Had my maiden flight today - quite windy and the plane got thrown around quite a bit with a 500mah battery. After getting things trimmed out, I upped the battery to an 800mah, and then 1.3mAh pack. Lots of fun and very easy to fly even with the wind. That said, I got overzealous and tried to look at my phone while flying since I had invited a friend to come out...I ended up losing orientation and nosing it straight in....
I was able to then see how easy it was to repair. A little packing tape and I was back in the air. Now to finish up my full size version.....and tiny trainer....and FT Cruiser.....and FT 3D....and.and.and...Wow this hobby really snowballs.
Exceptionally cheap and run at 5 Volts as opposed to the usual 12 Volts.They even come with a USB attachment to make them easy to test. I run them off of the battery balance plug. Just be sure to use two wires that are next to each other so you only attach across 1 cell.
Mmmm... but while that works you are draining one cell more than the others wich will cause the battery to take way longer to balance charge later..
If they run at 5V the ideal solution would be to feed them by the 5V output from one of the ESC BECs .. usually only one is used (to power RX and servos) to avoid issues so the other should be free
