I have a ton of CW props, and wanted to know if the thrust angle setup is "0" "0" (FT Alpha), are the any problems in using the CW props?
I bought the cheap sets of 1 CS and 1 CCW 6" props. (just swapping the motor to ESC wires)
You should know, if you are flying a pusher plane (like the arrow), then cw props are actually better. Because of their rotation the nut actually screws itself on using the motor torque.
