Great thread, I like your Mustang improvements, power system ....
Hey Nerdnic:
Uhu Por glue ( it is foam safe too ), Amazon link here, been looking for that stuff.
CraftyDan said it makes the best glue hinge for your foam models if you have an hour to spare.
******* Is this the best stuff to stick magnets to your plane? *****
http://www.amazon.com/UHU-POR-Styrofoam-adhesive-tube/dp/B000LKOC1M
Bruce Simpson of XJets mentioned in his video about epoxy, about some stuff he seemed to be calling acrylite glue, you would use if nothing else would work, it stinks and sticks good. I have not found what we have to buy here that matches that description.
Wonder if.... Is this what uhu-por is?
About power, do you like the Turnigy motors better than the Suppo? I remember the Suppo 2814/6/1400kv for $23 100grams, you reviewed on Altitude Hobbies, Now this motor here you like for this is Turnigy NTM 35-48 1100kv, since they don't refer to stator size, this is kind of like a 28mm motor and 173grams too.
I am wanting now to move on to larger motors so it's not such a challenge with the weight and construction, so am looking at planning and buying some lower kv motors like 1000 or 900 and going to 4s sometime. 2 of the best larger motors I have now are Cobra 2820/10/1170kv 142g $43 innov8tive with APC 10x6 on 3s thrust for 351w is 57.4 oz
When I study these ( Cobra an Scorpion mostly familiar with now ), those with the lower kv always have much lower NoLoad Tests. Typ for smaller or mid size motors around 900 1400 the Io tests are some current at 10v. like my 2820 above is 1.6A at 10v, and those with less turns have much higher Io, and less efficient. The real low kv motors show test like .94A at 20volts for like 500kv 250gram motors or similar. So this made me consider motors around 600 to 900kv you cannot go too low in kv or you really have to swing big props or get more cells, I want to keep props between 10" to 12"
Noticed you are using more motor for your projects and I have been looking at the foam warbirds 1100 to 1450mm and thinking of power systems to build a foam warbird
What are your favorite motors Nerdnic?
