Dreamwalker
Less than 250 Grams!
Some additional "Speedster" info.
I found this on the RCG forum, posted by rus1 & ec121connie
http://www.rcgroups.com/forums/showpost.php?p=27165583&postcount=18
Basically they centered the wing in the fuselage and increased the wing tip height from 3" off the building surface to 4".
(increased the angle of polyhedral.)
They said, "This solved the turning problem, and the plane flies much better."
ec121connie also..."added a blocking plate in the fuselage from the bottom of the swappable engine mount to the lower fuselage"... to counteract the..." large percentage of the generated thrust through the center section of the fuselage."
This modification seems to improve..."The airplane's ability to answer the rudder".
I hope this will help
Tom
Tom
