I think I've found a couple issues with the cut files on the P-47.
First is the battery box. The edge that glues on last is too tall. This makes the box somewhat out of square, and the formers won't fit over it correctly.
Second is the thin strip fuselage section that goes behind the cowl flaps. It ends up being too small. And, the #3 former won't go into it without crushing.
SP0NZ submitted a new resource: FT P-47 v1.0 Addendum - Update to part 15 for the P-47 v1.0 plans ** FT P-47 Plans Addendum ** Part 15 on the FT P-47 version 1.0 plans was actually a part from a different model. Flite Test sent me the correct file and I'm working to update the full plan set...
Fuse Skin 1 (Part #15) was incorrect in the original plans. The addendum correcting Fuse Skin 1 is the above comment, #113.
Attached is the Battery Box correction.
