ckleanth
I made and cut everything on my own also. And the cg is marked on the wing plans, little round dot, quite near the blue marked holes in thd base of the wing. I don't have my plane now with me so I can't measure..
found that. so basically you build it to plan, positioned battery and equipment to balance at those marks.
Did it flew straight with a bit of trim or did it need a lot of trim to fly straight at 50% throttle? If it needed a lot of trim was it up or down trim?
I guess because of dihedral when you fly at WOT it want to fly upwards like a trainer (and inverted want to dive to the ground)? is this tendency substantial? (to know whether to leave some dihedral in when we do the wings or to make it with no dihedral)
cheers
