Ft Racer Corona build.
The_slowest_hare
Hey everyone, I finished my ft racer today, unfortunately can't maiden it due to the New England wind. I'm second guessing myself now whether the power setup I have will be sufficient. I put in a 2212 1400kv with a 30 amp and an 8x6 prop. It's maxing 160w, will that be enough? I also have 9x5 and 10x6 props on the way as a back up.
slowjo
nice looking build
BATTLEAXE
Nice clean build, the Racer is a sweet flyer. Like its on rails if the speed is up. As far as the motor you chose i would use the 9x5 on 3s, the 8x6 on 4s. Also depends on whether the ESC could handle 4s
The_slowest_hare
Good looking build. (y) The 8x6 should fly it. What prop is recommended for your motor? If you can go bigger, I would, since the fuse on the racer is pretty wide.
Thanks bud, the 8x6 is what's recommended, I hooked my watt meter up and with the 8x6 running a 3s it pulled 160w max and around 15/16 amps. Once I get the 9 by 5s in I'm going to meter it again with the hope that it'll have an amp draw under my 30a esc. Fingers crossed! I should have mentioned it in the original post but this is my first scratch build.
The_slowest_hare
Thanks a lot man, I've done some run ups with the 8by6 on 3s but I'm new to all this and I couldnt tell if it was strong enough, I know they say 100w/ lbs. And that the plane is 1.1lbs on paper but I suspect mine is a little heavier so the 160w it pulled might still be under powered. It's my first non trainer so I'm okay with it not being a speed demon but I don't want it to be a dog either.
mrjdstewart
great looking build.
kinda need an AUW? how much does it weigh fully loaded? without this it's all kinda guessing.
i fly my Racer on a 2115/10 emax (old c-pack) with a 9x4.5 prop, 40A esc, 4S-1000 w/ an AUW of 697g.
it is not fast, and really not my favorite flyer. looks good though. :LOL:
good luck,
me :cool:
The_slowest_hare
Took some pictures this morning of end result
The_slowest_hare
So an unexpected sudden landing...?
Haha actually yes, I took it out behind my house in a small field to just get some quick launch and lands and when I tossed it, it torque rolled to the left which I tried to account for with right aileron which caused it to bank harder landing pretty hard on the nose and breaking the prop.... I'm a dunce... I messed up when I was checking aileron movement and had them backwards 😖. Thankfully nothing else was damaged. I'm going to wait for the bigger props to come in before trying it again.. I don't have a lot of faith in the 8by6
The_slowest_hare
So you're into the RC trucks - cool! I am hoping to get the TRX-4 kit at some point. I've got an E-Revo 2.0 VXl and it's a beast!
Yup, they're what got me into the hobby years ago. I have a 2wd stampede with a brushless motor, the element Enduro (which I absolutely love, definitely get a crawler!) And a wpl c14 1/16 off banggood that I've heavily modded.
The_slowest_hare
I'm really tempted to try it this morning though, no wind whatsoever
The_slowest_hare
She did it guys! Flew a little too nose heavy but very controllable. I got the 10x6 props in today put one on and hooked up my watt meter.. 189 watts at 19.3 amps, was going to wait for the 9x5s but I think the 10s might be my go to. Who would have thought.
