My previous FT Racer was built according to plans and modified with time until its demise and since then I always wanted to build another. Loved flying that plane!
This time it will be different:
-Nerdnic style speed wing with aluminum spar, flaps and will be removable. I may add wing fences between the flaps and ailerons and wing tip fences.
- Narrow fuse for aerodynamics. The nose will be enclosed.
- Feathered tail reinforced with carbon fiber rod.
- For the motor I will be using either my Propdrive 2836 2200KV with a 7X5 prop (currently on my FT Mustang with a speed wing) or a Turnigy 3536 1250KV with either a 8 or 9" prop. Suggestions?
- 9 gr servos, metal gear on elevator and ailerons. The tail servos will be installed internally in the fuse above the wing.
- Battery will be 4s and will be installed under the removable turtle deck/canopy.
Let me know what you think. I'd love to hear any suggestions, ideas etc.
Wing ready to fold.
Feathered edges.
Glued together and control surfaces cut.
Vertical stab ready to be folded and glued
Horizontal stab trailing edge.
Reinforced the horizontal stab rudder groove with some epoxy and nylon. It was pretty strong without but I did it anyway for some peace of mind.
Tail assembled.
New wing profile traced on the fuse.
The fuse was narrowed down from 3 5/8 to 2 7/16"
Wing ready to fold.
Feathered edges.
Tail assembled.
