rgc213
I just got the new 2218 Radial motor for the edge I'm building, and I'm pretty excited.
However, the nut for the shaft has what looks to be a lock nut and does not fit all the way onto the shaft (stops at the plastic thing inset into the nut).
I was wondering if you need to use a spacer to get the prop closer to the end to allow the nut to tighten against the prop? and if so, what do you use as a spacer? Or should i get a nut that will screw down all the way?
Thanks,
reub
Thanks,
reub
