Hi everyone, I need some help with my SE5. I just can't seem to figure out what it needs to fly.
The current setup:
A pack motor and esc with 5x3 GWS ccw prop
800mah 3S all the way forward almost under the motor
CG balanced on the upper wing crease
Throws per the included throw gauge.
On take off from the ground it will get airborn and immediately roll to the the left. If I get in the air it acts super tail heavy. If not, it'll cartwheel into the grass.
I managed to hand launch it and it was a struggle to survive. Some tail heavy porpoising, stall turns, you name it. Was lucky to crash gently.
I've moved the battery around with no success and added even more nose weight.
I must be missing something. All my other FT planes fly great.
Open to ideas.
The current setup:
Open to ideas.
