I had neither clear skies nor soft landings. The maiden of the Otter went well, especially after turning rates down to 75%. Unfortunately I drilled it into the ground on the 2nd flight and the main damage was that the elevator servo stopped working. The wire is hard to access/replace, so may just cut the wires and solder a new one on instead of messing around with the extensions that go through the tail.
As for the mini sea duck, this one always made a high pitched noise at high rpm, a member of my club said the props were too loose, but it still did it after I tightened them so I thought nothing of it. Well, the right prop had a rapid unscheduled disassembly during takeoff on the 3rd flight, and the 2/3 blade prop imbalance likely put too much torque on the motor mount which caused it to break off and strike the leading edge of the wing. Luckily I was still low and slow, so it wasn’t too hard to minimize the damage on the crash landing with 1 motor.
My girlfriend got a video of the maiden of the otter which I am about to upload to YouTube and link here.
