FT Simple cub CofG
wildjaych
When balancing the simple cub should the top wing be level or the nose level?? Has anyone had to add weights to tail?
wildjaych
Wing look level but nose is not
That looks pretty good, you want a slight nose down for good handling. Is that with the battery in?
I would fly it if it’s sitting like that. Maybe put a small spacer under the wing leading edge to add some incidence if it isn’t as floaty as you might like.
