A few pics that should help. Basically with the tail flat I glued in the bottom vertical piece. I then folded the tail based on the gauge in the plans and glued along the seam. This locks the “v” together with the vertical piece.
The fuse is typical B folds with the bottom plate that has two notches for the bottom of the vertical piece. After the fuse is glued I then cut out a portion of the top plate (blue reference line on plans). The v tail then drops in with glue on the bottom of the vertical and where it meets the fuse.
I think it ended up looking pretty good and it’s very strong. I lucked out in that the servos fit perfectly and butted up against the v tail vertical piece.
