psguardian
maiden!
I have been waiting for a motor glider in the FT series! Soo glad it is here. I used black sheets for the wings & put bright green (right) & bright pink (left) bands around the end of the full air foil to assist in orientation & contrast against the white/grey winter skies of the Pacific north west. For control horns I used disposable flossers.
I had to get creative with the power system, because I'm working from a scrap box of wrecked scratch builds. I prefer to glide, but have no high start nor a tow pilot, so I moved the wing back an inch & used the following setup:
The only 1300kv BW I have was defective, so I'm using a 1700kv turning a 7x5E.
The only servos I had avail are the 5gr. Cut the first hole off of the single arm horns & they fit just right. They are strong enough to pull out of a 150ft dive (on this plane), so I'm I'm not worried about not having their 9gr big brothers.
The only 3s I have are 204gr 2200mah turnigy packs, so I an using two 500mah 2s in parallel for a 2s 1000mah.
The moved wing provides me with Bixlers c of g & works wonderfully on glide, unfortunately even with the added down thrust she pitches up hard on WOT. I know it would not do this in it's proper configuration, and accept the quark as the price I pay for not waiting until I can order proper packs.
6min of WOT pulls a perfect 80% from my current setup. My maiden was in high wind where i could barely gain ground upwind, so it was a 6min flight. The next day however... Those six 1min climb outs provided me with nearly 20min in the cold 25°f morning of light breezes.
Thanks flitetest,
~psguardian
Thanks flitetest,
~psguardian
