FT Simple Soarer
Air Force One
Hi,
I bought 50 sheets of flitetest foam. I was planning on building the Simple Soarer. Problem is, I only have 3S 1300mAh or 2S 800mAh. Will it run on either of those? or do I need to buy some 3S 800 mAh.
Thanks
Kevin
daxian
hi airforce ...
they will both work fine ......2s will be a little less power but will still get it up in the air, 3s will give you longer flite time @ lower throttle settings ,depends on the motor !!!!cg will need to be adjusted with the heavier battery of course...
