The FT Simple Storch can be setup with all kinds of fun configurations. The build video covered one setup.
Leading edge slats come with your speed build kit and are also included in the free plans.
Separate ailerons and flaps is another mod you can setup. For this, you will need a y-harness connection for your servos.
In most cases, you'll need to enable flaps on your radio.
The window decal kits is another way to add that classic Storch look to your classic foam board warbird.
Thanks again for all of your support. Be sure to click the links below to check out the main build video of the FT Simple Storch as well as the review!
