FT Spitfire motor and props
grzecho16
Hi, I've tried to use a small motor I had laying arround and it's way too underpowered, so I decided to give it a better setup. I think I'll go with this motor https://hobbyking.com/en_us/turnigy-d3530-14-1100kv-brushless-outrunner-motor.html but I have no idea what propeller I should get, there are so many options. I want to get a couple of different ones just to feel what I like, any recommendations? One more thing, will 30A ESC be enough or should I get 40A one just to be safe?
mach1 rc
A 9inch prop should be fine and 30 amp esc should work unless you run it on 4s.you would have to trim the propeller about an inch if it's on 4s.
I agree with @mach1 rc . A 9 inch prop and 30 amp ESC will work on 3S. I believe you even use a 10 inch prop, so long as it were shallow pitch, something like a 10x4. I don't think I would try a 10x6.
I always use a watt meter when trying a new motor/prop combo.
