FT SPITFIRE
Jaxx
Yes, I did the whole plane in the brown (Kaki) color then masked off and did the green, be careful of what type of tape you use as you can pull off the brown paint when removing the tape, also I did the bottom with light blue. not shown in my pics. for the decals I just printed my own designs off on my printer, and covered the front side with clear tape, and then cut out the shape, applied 3M spray adhesive on the back side and slapped them on worked great!
NewZee,
Thanks for the great information! I'll be using painter's tape for this.
Flynn
Jaxx, I used the painters tape. One tip, pull off a piece and stick it to your pants. I was wearing jeans, pull tape piece off your pants. Do that like 3 times and then stick it to your cutting board. Cut your pattern, and then stick it to your plane.
I painted mine green first then masked it off for the brown color. I would do the lighter color first.
Jaxx
Flynn,
Thanks for the great tips. I would never have thought about doing that. I will definitely use your recommended techniques. I’m itching to try out the new airbrush setup. What type of paint did you use?
xuzme720
Dedicated foam bender
Acrylic seems to work best thinned to flow through the airbrush. You can use water for thinning but Chad has recommended windex, from tips on the forums. I used it also and it seems to work well. I rushed mine (rain was coming)and put too much paint on too fast, so I had some runs. Before I got impatient, it was really working well! It still looks ok, just not as nice as I know I can do.
I am working on a custom canopy. Wanted to get your guyses thoughts. Silly little forum won't let me upload the pictures here. Sorry about that.
http://www.pasteall.org/pic/61331
http://www.pasteall.org/pic/61332
This is still a prototype of it, but I think it is ready for some color! Gonna try to add some graphics to it.
Edit: Does anyone know the proper paint scheme for a US Spitfire? I would like to make mine look as realistic as possible, since I am going to paint it, might as well do it right.
DogLover -
Also check out Cybermodeler Online: http://www.cybermodeler.com/aircraft/spitfire/spitfire_profile02.shtml .
Blenderite
Professional Crash Pilot
Thanks for the links 808. I now have some stuff to work with.
I ended up using tongue depressors on the outside of the plane, since my internal supports where already glued in. Just used a small square though, seems like it will be a lot tougher. Kinda surprised the Flite Test guys didn't include anything about this. They crash often enough! They should know!!! lol
Also, I am putting on landing gear, since I have a lot of really short grass and asphalt around me. I plan on having the tail wheel connected either to the rudder or to the servo that moves the rudder, so I can steer easily on the ground.
One more thing. It is kinda a pain to remove the power pod, cause I have to remove the wing to remove the servo extensions so I can take the power pod out! I have never seen a FT video about how to wire all your wires and stuff for the power pods. Any tips?
Flynn
Flynn,
Believe it or not I used Lowes rattle cans. The Valspar brand. I was thinking that I needed Flat paint but they only had Satin in the colors I wanted. I was really happy with the way it came out. I minwaxed it first of course. I did airbrush some stripes on the Blood Wonder and for the airbrush I use the Tamiya paint from my local hobby store.
The decals were from Hobbyking. Their set for the Durafly Spitfire http://www.hobbyking.com/hobbyking/...arine_Spitfire_Mk_24_Replacement_Sticker.html
I wish the quality was better. Next one I'll try painting them or the printable ones. I haven't tried the "print your own" decals, don't know how that works
I'll see if I can post a picture . . .
(woohoo! 100 posts, lol)
NewZee
I printed my own decal designs off my printer at home, put clear tape on the show side, and then cut out the shape with scissors, sprayed 3M adhesive on theback side and stuck them on worked great!
Jaxx
You guys are awesome! Thanks for all the great information. I'm taking lots of notes and will be applying some of these ideas to my future builds.
DogLover,
I had some really long servo extension in my first Spitfire, so it allowed me to pull the power pod out through the front of the plane and connect/disconnect it. I really disliked having to constantly remove the wing, as the tension from the rubber bands was causing the foam to buckle. The drawback to long extensions is all the excess wire that is in the plane when the power pod is installed. This is one of the reasons I decided to build one with a non-removable wing and non-removable power pod. I plan to cut and form some 1” insulation foam from Lowes to make rounded part of the fuselage, right above the power pod. It will be a single block of foam that runs from the nose to the front of the cockpit. This is where I got the idea (post #6): http://forum.flitetest.com/showthre...ane-i-have-Build&p=65247&viewfull=1#post65247. What I'm going to do differently is make a section of that solid foam block removable. It will be held in place with magnets like many of the canopies on HK models (see picture below). I will be able to access the power pod by simple removing the section of fuselage right above it. I am also making a modified FT power pod. The side walls will be about 2” tall, with no tabs, and the firewall will mount flush with the top. That will leave a gap directly under the firewall, allowing air to flow through the power pod. Since the power pod will be deeper, than the original FT version, it will allow me to easily fit the battery inside it. I know it's probably hard to visualize, I will post pics when it's done.
Imprez
That is a great idea, I will try using the same method om my next build! This time i used a combination of spray paint and painting by hand with a brush. I am quite happy with the result but it was quite time consuming. Here's a few pics of my Spit in the field on a misty autumn morning here in Sweden:
Craftydan
Hostage Taker of Quads
Whats the difference between an 8x4 and a 8x4e?
8x4 is a prop size -- a generic designation giving diameter and a general idea of speed.
8x4e is a prop size and type. that e at the end means it's designed for general electric planes and a fairly rigid prop. they're are several others that are common -- ones I've run into:
SF (slow fly -- softer prop only meant to run at low RPM)
F (folding -- for powered gliders)
P (pusher -- prop is backwards to be run in a pusher config)
R (reversed -- prop is backwards to be run as a counter-rotating tractor)
There's bound to be others, and might even be a bit of variation between mfrs.
to answer what you're getting at -- which I should buy -- It's hard to say. It depends on the undesignated prop's manufacturer. If it's the same, there's a good chance it'll be a general prop suitable for both electric and gas engines, and therefor will be far more sturdy . . . and heavy. you'll also have issues mounting it to an electric motor from hub thickness. If it's a diffrent manufacturer, it's hard to tell -- if they only make electric props, it's just what they call their all-around prop.
Imprez
That looks great Imprez! I almost did those colors. I love the spinner and pipes.
Thanks! Yeah the colors are ok, I had hoped the blue would come out a bit more towards grey but that is maybe nitpicking a little :) Plane markings FT - D is a homage to Flite Test and David who designed the plane.
Since Flite Test crew likes big spinner I thought I go BIG, hehe. Pipes are from an old Guillows P-51 kit but could just as easily have been made from a jagged piece of foamboard.
This is my first build except a couple of Guillows rubber band balsa planes I built decades ago. You got to love the FT designs. Learned to fly this summer and the Spit is still in one piece, go figure :)
Blenderite
Good to know. Thanks! Someone needs to try making a flexible prop, so it doesn't break it you crash!
Craftydan
Problem with a flexable prop is it flexes when the air pushes against it -- undoing what it's there for. A well made SF prop will be pretty bendy and sustain a hit w/o damage, but aren't great for generating much power or speed. A poorly made SF prop is typically even more flexable, but also tend to be fragile and break under a stern gaze.
NewZee
Absolutley Beautiful! I like the spinner (what size) , the prop looks a little smaller than what I use (9X6), what size is it?
