Just wondering where you guys are mounting the battery. Seams a bit of a pain to remove the power pod each time. Mine fits in there very tight.[/QUOTE said:
I ended up putting my battery (1300 mAh 3s) under the power pod and as far forward as possible (almost touching the prop) secured with a velco strap coming out and down from inside the Power pod) note: I had to mke a small slot in the bottom of the power pod to pass the connector leads through. this helped me get the proper CG,
I agree it's a tight fit and a PITA!
I usually push the pod out through the center of the fuse (with wings off) with no prop on , then connect the alierion "Y" connector and secure the pod, then wings, then prop!!!
BTW your paint job looks great! Hope it looks as good after your first "landing"
